Update beim Festplattenoptimierer Raxco. Das Diskeeper Add-In für den Home Server kommt nun in Version 12.5 SP3 Build 310. Es hat zahlreiche Änderungen gegeben. Diese könnt Ihr dem Changelog entnehmen.
Client:
- Fixed ability to schedule Exchange datastore compaction.
- Fixed “Invalid parameter / namespace” defragmentation errors.
- Fixed testing of connection to an Exchange server.
- Fixed algorithm for determining thin provisioned drives in Hyper-V Guest.
- Fixed incorrect dumping of registry keys in PD support information.
- Fixed an error in setting exclusion periods via Group Policy.
- Fixed detection of drive types for attached iSCSI disks in Virtual Guest (vSphere and Hyper-V).
- Added logging of errors when communicating with Exchange 2010 servers to the application event log.
- Improved refreshing of drive type in Virtual Guest when Virtual Awareness setting is enabled/disabled.
Console:
- Fixed several issues when pushing a Configuration Profile to clients.
- Fixed saving of database data retention parameters.
- Fixed usage of proxy settings during client deployment.
- Fixed pushing of Configuration Profile during client deployment.
- Improved GUI in PD client deployment wizard.
- Allow display, assignment and deployment of Schedules, Configuration Profiles and License Keys to both PD12.5 and PD12.0 clients.
Informationen direkt vom Hersteller gibt es hier: http://www.raxco.com/home/home-server.aspx
Via: MSWHS
